DuckNet
Oct 21, 2022Tutor
Fan Noise GS324P
Looking for 24 port switch with at least 8 POE+ ports. But I see that many units have fans. Can anyone confirm that the fan on the GS324P or other switch in this series - including managed like G...
- Oct 24, 2022
Welcome to the community!
The GS324P has an acoustic noise level of 31 dB given that the switch operates at 25°C in which it is generally considered to be quiet. The same thing goes as well for the GS324TP which has an acoustic noise level at 32.8 dB.
JeraldM
NETGEAR Community Team
AlexUnder
Jul 25, 2024Aspirant
I can confirm that GS324PP switch is very quiet, as quiet as a hair dryer with a bad cough. Got one setup today, if you like a lot of fan noise in your environment I definitely recommend this one.
