The fan speed is fixed to 4000 RPM, can this be changed to smart as the switch is not installed in a server cabinet.
the tempeture is als stable. i think it should ajust itself according toe what the switch needs for cooling.
I would like to know if this is possible.
2 Comments
- BrianLNETGEAR Moderator
Hi Dimitri_vanes,
A quite similar thread has been posted before (you can see it here). Let me check with our Switch Engineers if this feature request has been logged.
Kind regards,
- StevenTiboschFollower
Hi,
I have the same issue with the MS324TXUP its WAAAAAAAY too loud. Very annoying when used in residential buildings
