Digital999
Dec 07, 2022Luminary
FS108PNA -- Get RMA for replacement
I have a POE switch that has two failing ports. I cannot find out how to get an RMA for this product which has a "Lifetime Warranty" and is registered under my devices. Either there is a failur...
Dec 07, 2022Guru - Experienced User
- Digital999Dec 07, 2022Luminary
That link leads into a circular set of web pages with no way to see hardware support.
BTW, I have been a Netgear user for the past 12 plus years with many products registered.
And that is why I requested help -- failing hardware that is registered and covered under hardware warranty but the only link is to go to the 'community forum'.
Does Netgear employ humans that can help?
- plemansDec 07, 2022Guru - Experienced User
Did you try contacting them via phone?
https://my.netgear.com/support/contact.aspx
There's a business number on there.
Thank you for your reply -- but it was just speculation.
Absent a case number the telephone wait time is over 90 minutes for an agent.
- schumakuDec 11, 2022Guru - Experienced UserThe registration is the best place to start with. All your registered devices will be listed under https://my.netgear.com/ - easy to file eg. a hardware replacement process from there. Bo calling, no email submission et all required.
