Digital999
Dec 07, 2022Luminary
FS108PNA -- Get RMA for replacement
I have a POE switch that has two failing ports. I cannot find out how to get an RMA for this product which has a "Lifetime Warranty" and is registered under my devices. Either there is a failur...
Digital999
That link leads into a circular set of web pages with no way to see hardware support.
BTW, I have been a Netgear user for the past 12 plus years with many products registered.
And that is why I requested help -- failing hardware that is registered and covered under hardware warranty but the only link is to go to the 'community forum'.
Does Netgear employ humans that can help?
Dec 07, 2022Guru - Experienced User
Did you try contacting them via phone?
https://my.netgear.com/support/contact.aspx
There's a business number on there.
- Digital999Dec 07, 2022Luminary
Thank you for your reply -- but it was just speculation.
Absent a case number the telephone wait time is over 90 minutes for an agent.
- plemansDec 07, 2022Guru - Experienced User
The community forum is where members of the public help out.
You either need to go through the support site to get a case number/rma going or call them.
there's nothing to do on the forum to get that.
The reason that I opened this discussion is to somehow embarrass Netgear so they stop pointing to the community forum instead of having a way to open a case. I have many devices registered, my clients have hundreds.
You are a nice person but what I want is Netgear management to pay attention.
