tskiba
Apr 21, 2016Initiate
FVS318G – ProSafe 8-port Gigabit VPN Firewall
I apologize if this is too basic a question, but I'm a networking novice who needs some advice. Home internet consists of comcast cable piped thru a Netgear CM600 cable modem which then feeds a ...
- Apr 21, 2016
Hello tskiba,
Welcome to the community!
If this is an FVS318G version 1 you are a little out of luck since the maximum WAN-to-LAN throughput that it can handle is just about 11Mbps. However, if you have a version 2 (FVS318Gv2) then I would say it is an issue since the v2 can accommodate up to 250Mbps. If you want me to check what version you have, you can send me a PM of the serial number.
Looking forward to your response.
Thanks,
JohnRo
Apr 21, 2016NETGEAR Employee Retired
Hello tskiba,
Thanks,
- tskibaApr 22, 2016Initiate
Thanks. Based on the serial number this appears to be a v1 unit. Will be upgrading to a v2 unit this weekend.
