tskiba
Apr 21, 2016Initiate
FVS318G – ProSafe 8-port Gigabit VPN Firewall
I apologize if this is too basic a question, but I'm a networking novice who needs some advice. Home internet consists of comcast cable piped thru a Netgear CM600 cable modem which then feeds a ...
- Apr 21, 2016
Hello tskiba,
Welcome to the community!
If this is an FVS318G version 1 you are a little out of luck since the maximum WAN-to-LAN throughput that it can handle is just about 11Mbps. However, if you have a version 2 (FVS318Gv2) then I would say it is an issue since the v2 can accommodate up to 250Mbps. If you want me to check what version you have, you can send me a PM of the serial number.
Looking forward to your response.
Thanks,
JohnRo
Apr 21, 2016NETGEAR Employee Retired
Hello tskiba,
Thanks,
tskiba
Apr 22, 2016Initiate
Thanks. Based on the serial number this appears to be a v1 unit. Will be upgrading to a v2 unit this weekend.
