bergpr
May 10, 2021Aspirant
gateway addres 169.254.29.193 instead 192.1681.1.
I attached my new GS108 switch but it connects to 169.254.29.193 on my ASUS gateway, instead of the correct address 192.168.1.1.
How di i change this into the right address?
Peter
- I solved it by setting the gateway at 192.168.1.1 in the network adapter ip-settings, under Advanced.
Success.
The GS108 is a unmanaged switch. Even the more expensive configurable or smart manageable don't make use of Zeroconf addresses like 168.254.x.x/16 - and it's IP is only for local management purposes, and not for routing.
If a system connected through such a switch to the router - assuming the port on the router/gateway where it's connected is working - and there is no DHCP server available, no MAC address reserved or allowed to access the router, (and obvious without a static/fixed IP configured).. many modern OS fall back to Zeroconf addresses. This is not something assigned by either the switch or a router.
Start with checking the link speed negotiated - check if the LEDs on the switch, computer port, and router show an active and assumable working link.
- tayderAspirant
i am having the same issue only mine gets registered as 169.254.166.188 all lights green and ports plugged in securely router reset several times switch reset several times wont give internet connction or local networking due to mis configured IP. how do i fix this? or do i just return it for something else?
- bergprAspirantI solved it by setting the gateway at 192.168.1.1 in the network adapter ip-settings, under Advanced.
Success.
