choifoto's avatar
Sep 27, 2022
GS 305 dropping internet connection
Hi,
I have a cable modem-->GS300-->wireless router set-up.  Once I hook everything up, the internet works for a few minutes, then the connection terminates.  I'm not sure if it's the wireless modem that is doing this.  Anyone have suggestions?
Thanks.
  • plemans's avatar
    It should go modem---->router--->switch (GS305)
    • choifoto's avatar
      choifoto
      Tutor
      Thanks for your reply.  I can't connect the switch to the router because they are in different locations.
      • plemans's avatar
        Most ISP's only support 1 public ip address. The router take that 1 public ip address and assigns private ip addresses to the devices on your network (simplified version).
        So if you're device is a modem only device and you connect a switch to it, that address can get assigned to the wrong device.
        Its why it needs some type of routing device connected to it before the switch.
ProSupport for Business
