burakozdmr
Mar 16, 2023Follower
GS105 communication loss
Hello all,
I need some help about GS105 switch. I have a camera system. I am using GS105 switch inside the camera and there are 3 ethernet device connected to my gs105 switch. i have another switch LB-Link model BL-SF801 to stream videos and show that video stream on a field pc. Also some ethernet devices such as computer and GSM router are connected to that switch. I have a cable between these two switch to provide communication between cameras and my field computer. Somehow, after a while, communication is missing between these two switch despite all other devices communicating with these switches. When i check the system i am not able to see any light blinking on the related port numbers for both switch. Also the target devices does not response to ping. I have changed the cable and sockets but situation is still same. To undestand the problem, i restarted (power cycle) to LB link switch, but it did not solve the issue. Because of the netgear is not reachable physically to make power cycle, i restarted all system together. After full system power cycle somehow problem disappearing and they are communicating again. I am not familiar about that switch technology. Can someone explain me why i have that problem. And what are required diagnose activities to solve that issue.
Regards.
Burak
No RepliesBe the first to reply
