JLO464
Mar 18, 2021Aspirant
GS105 v5 auto negotiation issue
After some assistance I have GS105 v5 which is connected with all cat 7 cables. when connected to the switch the PC and NAS are shown as 1G (two green lights) and this is the case for any of th...
antinode
Mar 18, 2021Guru
> [...] The wan which is direct into my BT Smart Hub 2 albeit through
> cat 7 cable in the house only connects at 100 (i green light) in any
> port. [...]
What, exactly, does "The wan" mean to you in this context? What,
exactly, is connected to what, exactly? (Hint: If a device has
different types of Ethernet ports, then "connected to device" is not
enough detail.)
"in any port" on which device?
A router can have a WAN side and a LAN side. A network switch is
all-LAN; all its ports are equivalent.
If you have one cable which causes a problem, then I'd suspect that
one cable. All eight conductors are needed for 1Gb/s speed; only (the
right) four are needed for lower speeds.
> [...] I had some cabling issues one resolved this has been flying.
Huh?
If you're installing your own connectors, then I'd inspect the work
carefully. One bad connection out of sixteen could cause this.
> I suspect the answer is a new switch [...]
Does the problem move with the switch, or with the cable?
- JLO464Mar 26, 2021AspirantTo simplify all new CAT 7 cables and Cat 6 through the house. cable from router direct into pc gives full Gb but pull from pc and put in switch only 100. pc to switch gives full Gb I have tested in every port and the same conditions stand.
