othni
Nov 02, 2016Aspirant
GS105e can not login or factory reset
I have a couple GS105E switches at work. I am using the latest ProSafe Utility version 2.3.20 to access them. The switches show up in the utility, but do not accept any password (or blank) to c...
- Nov 10, 2016
Hi othni,
We get the information: FW v3.01.28 is an official release for TOTALPLAY, which is customized product.
The default setting difference was requested from TOTALPLAY, so TOTALPLAY should know the default password is not “password”.
Please contact Totalplay directly because of only Totalplay know the password. :smileyhappy:
Thanks for JohnRo’s help, too.
NETGEAR Employee
JohnRo
Nov 03, 2016NETGEAR Employee Retired
Hello othni,
I have deleted the image you have attached since it contains the serial numbers of the devices. I was able to check one of the devices' serial number and it shows up as a v1. The default password for v1 and v2 is just "password" (no qoutes). How did you reset the device? Also, please make sure you are using the latest version of the utility.
Thanks,
othni
Nov 03, 2016Aspirant
Hello
I have tried "password" but it does not allow me to login.
As I stated in my first post, I am using version 2.3.20 which seems to be the latest available in the support area.
I have tried to reset the switch by pressing the reset switch at the back for 30 seconds.
I have tried with the switch on and also off and turning the switch on while the reset button is pressed.
How do I know the reset worked?
