clktex
May 18, 2024Follower
GS105v5 Connectivity to internet router failing intermittently
My unmanaged switch appears to be failing. I've started having intermittent loss of connectivity to ATT Fiber internet through its gateway. I've checked with ATT and they say the gateway is getting...
May 18, 2024Guru - Experienced User
I don't believe there are FW updates for unmanaged switches. They fail due to going bad, faulty or possible bad power adatper or bad cabling.
Swap cabling. CAT6 is recommended.
Try a different power adapter with same power specs.
Remove the GS switch and go directly to the host router with your devices and compare.
