pixeldroid
Jan 24, 2022Aspirant
GS108 Stops Working
Hello, I have ATT fiber with runs thru an ARRIS BGW210-700 gateway. I was using a very old switch which shutdown, so I upgraded to a GS108. It worked without a hitch for a day or two, but then this ...
Jan 24, 2022Guru - Experienced User
If plugging in a new device works, its not the switch.
Look at the router. Maybe its lease time is expiring and its not auto-renewing.
pixeldroid
plemans wrote:If plugging in a new device works, its not the switch.
Hmm. When the internet stops working on my computer, all the other devices on the switch also lose their connection. It is my guess that if I plugged in a new device before toggling the power on the switch, it would not get connected. I've not encountered expired leases in the past, and if that is the problem, then the leases of all the devices connected to the switch would be expiring at exactly the same time everytime this happens. Additionally the lease on the computer connected to a different router port is not expiring.
- plemansJan 24, 2022Guru - Experienced User
You can always try a different switch. Or try to RMA it
