probedb
Jul 26, 2015Tutor
GS108 to GS108T but only 100Mbps between them?
Hi, I have both a GS108 and a GS108T connected together. The GS108 has two PCs connected, both connecting at 1Gbps. The GS108T has 6 100Mbps devices (avr, blu-ray player etc) and a gigabit Asu...
probedb
Jul 26, 2015Tutor
How very embarassing...I thought I'd checked the cable, cut the ends off and recrimped them with new connectors...and it worked. Doh.
DaneA
Jul 26, 2015NETGEAR Employee Retired
Hi probedb,
Thank you for your feedback.
Don't get embarass... its alright... we're humans :smileyvery-happy: I am glad that the cause was figured out and it is now working fine. :smileyhappy:
Cheers,
DaneA
Netgear Community Team
- probedbJul 26, 2015Tutor
Many thanks :)
