banyoo
Nov 04, 2021Follower
GS108LP POE power drops
Hi all, I am running 4 cameras connected to different Netgear Switches over POE. 3 of the cams are connected to 2x GS108LP, 1 cam on Port 1 (Switch 1) and 2 cams on Port 1+2 (Switch 2), the...
DaneA
Nov 08, 2021NETGEAR Employee Retired
Welcome to the community! :)
I suggest you to open a support ticket with NETGEAR Support at anytime here. Kindly state the status of your GS108LP switches as well as you may include the link to this post. If your GS108LP switches has been proven faulty, an online replacement will be processed for as long as the switches are still within hardware warranty.
DaneA
NETGEAR Community Team
