jhg
Jun 22, 2024Aspirant
GS108LP switching works, power light is off, POE does not work
I have a GS108LP that works fine as a plain switch, but won't provide POE. I purchased it originally to use with a device that, as it turned out, required passive POE instead of 802.3af. So it's be...
BrianL
Jun 24, 2024NETGEAR Moderator
Hi jhg,
Welcome to the Community!
Thanks for sharing your findings. If the switch is powered via the included PA that came with it, it can power up to 60.5W max POE budget in all of its 8 ports that support both 802.3af and 802.3at. If the device continues not to supply power on several tested POE devices, we can presume that it is defective.
You can refer to the product installation guide for more information about the device LED and setup.
Kind regards,
BrianL
