girlgeek's avatar
girlgeek
Follower
Aug 15, 2017
GS108v4 and Broadcast Storm Protection
does anyone know if the switch is set to Broadcast Storm Protection as disabled???
  • Hi girlgeek,
    The GS108v4 it's an unmanaged switch and doesn't support broadcast storm protection so it's disabled.
    If you need broadcast storm control I recommend our equivalent plus switch that's the GS108E where the broadcast storm control is supported.
    Hope it helps!
    Xavier Lleixa
    NETGEAR CBU PLM
1 Reply
  • XavierLL's avatar
    XavierLL
    NETGEAR Employee Retired
    Hi girlgeek,
    Hope it helps!
    Xavier Lleixa
    NETGEAR CBU PLM
ProSupport for Business
