BudMcG
May 14, 2021Follower
GS108v4 with multiple gateway address's
I have a home network with a dozen or so "clients", some wireless. My router, a Linksys 848, has 4 ethernet ports and 2 of my clients require a direct LAN connection to the router. Each of the other ...
schumaku
May 14, 2021Guru - Experienced User
These unmanaged GS108 switches don't supply e.g. default gateway IP addresses at all. Neither do Plus or Smart Managed Pro switches btw.
You simply can't mix two subnetworks and broadcast domains on the same flat network - that's the only problem with your network design here.
