Bluhawk
Jun 13, 2025Tutor
GS108X Rack Mounting?
Is it possible to get OEM rack mounting ears for the GS108X? There seems to be screw holes but I can’t find brackets anywhere. I’m not interested in the 3D printed stuff. Thanks Phil
- Jun 17, 2025
I sent an email to customer support and unfortunately got no reply. I solved this with different sized brackets for left and right. Unit is off-centre but fits ok.
PhyinLan 4.25” (“Large”) on one side and 5.63” (“Extra Large”) on the other. Not cheap but done. Fits great.
Now, the SFP+ cable I have is only running at 1Gb. The instructions show there is a compatible 10Gb cable….mmm.
Bluhawk
Jul 02, 2025Tutor
The old cable was an SFP+ DAC. I’ve swapped it for a Nergear AXC761 from eBay and now connects 10Gb. Sorted. Too many variables to work through specs and compatibility to work out the reason.
