kmmcd's avatar
kmmcd
GS116 & STP cable
The GS116 has what appears to be a ground lug on the rear. I measure 0 ohms resistance between the RJ45 jack metal frames and internal tabs and this lug. Presumably, the metal plug of a STP cable wil...
  • schumaku's avatar
    Apr 21, 2018
    kmmcd wrote:
    The GS116 has what appears to be a ground lug on the rear. I measure 0 ohms resistance between the RJ45 jack metal frames and internal tabs and this lug. Presumably, the metal plug of a STP cable will contact these tabs.
    Yes, of course.
    kmmcd wrote:
    If I connect the rear lug to ground of another piece of equipment, will this switch effectively support STP shielding?
    Sure.
    kmmcd wrote:
    The manual does not mention this lug, and the specification sheet indicates that the connectors are UTP connectors.
    Looks like a mistake on the almost 10 year old data sheet of the GS116 - the newer GS116v2 data sheet (from around 2014) does no longer talk of UTP ports (what does make no sense - as there is perfect shielding/grounding capability in place).
ProSupport for Business
