one2one
Jan 29, 2018Aspirant
GS205 keeps dropping connection and re-connecting.
I am connecting this via a Virgin Media super hub, and it keeps dropping the connection, and reconnecting at random. I am using windows 10. can anyone help? I have all cat6 cables connect...
- May 08, 2018
thanks for your reply, it did work for after changing ethernet setting in my internet provider router (SKY). i changed the ethernet setting from Gigabit to fast ethernet and every things worked perfectly so far.
one2one
May 08, 2018Aspirant
Never found the solution, tried different leads, attaching to different ports.
nothing worked, so i threw the useless piece of rubbish in the bin and bought a different make/model which works perfectly.
alshatti82
