one2one
Jan 29, 2018Aspirant
GS205 keeps dropping connection and re-connecting.
I am connecting this via a Virgin Media super hub, and it keeps dropping the connection, and reconnecting at random. I am using windows 10. can anyone help? I have all cat6 cables connect...
- May 08, 2018
thanks for your reply, it did work for after changing ethernet setting in my internet provider router (SKY). i changed the ethernet setting from Gigabit to fast ethernet and every things worked perfectly so far.
DaneA
May 08, 2018NETGEAR Employee Retired
Hi alshatti82,
Welcome to the community! :)
Since the GS205 is an unmanaged switch, I suggest you to open a chat or online support ticket with NETGEAR Support at anytime and let them know about your concern. If ever the GS205 switch is declared faulty, be ready to submit a .doc or .pdf copy of the Proof of Purchase or Sales Invoice of the GS205 switch for warranty verification. If ever the hardware warranty is still valid, an online replacement will follow.
DaneA
NETGEAR Community Team
alshatti82
May 08, 2018Aspirant
Thanks, the problem seems to be solved so far.
