brkorb
Jan 19, 2020Aspirant
GS305 power port size
I'd like to know the size of the power port so I don't have to order the USB charge cable with a gazillion heads:
I have a bunch of variable voltage power supplies, but every one of them jumps from 4.5 volts to 6 volts and you apparently need almost precisely 5.0volts. So with lots of USB charging plugs lying around, I could do that, if only ...
For now, I'll get the one with lots of ends. I just wish these things were sized. :(
Thanks to anyone who can give suggestions "for next time".
I decided to try 4.5 volts. Works fine. That's 10% low, outside the +/- 5%, but it works.
1 Reply
- brkorbAspirant
