b1k3rdude
Oct 07, 2023Aspirant
GS305 (v1 & v3): speed limited to 100mb/s.
Bought this switch a few years ago and didnt realise that all this time the issue with the speed wasn't the Pi3 that was connected to it but the switch itself. For some bizzare reason that I can't fa...
schumaku
Oct 08, 2023Guru - Experienced User
More than strange. Do he Archer P9 and the RaspberryPi3 indicate GbE link speeds?
- b1k3rdudeOct 09, 2023Aspirant
Evening
Correct as evidenced by the test mentioned in the OP, where I plugged the Pi direct into the Tp-link.
In the meantime I found another old netgear switch (GS605), I will insert that in place of the Tp-Link and see what results I get.
