jj1988uk
Jun 05, 2022Follower
GS305 with PS4: manual IP address / internet connection failed
If I connect my PS4 directly into the wall ethernet then it works fine But I recently bought a Netgear ethernet switch (GS305) so that I can connect my PS4 via ethernet but also have my wireless ...
Jun 05, 2022Guru - Experienced User
Try another switch? Possible bad switch?
Check your LAN cables as well. CAT6 is recommended.
schumaku
Jun 12, 2022Guru - Experienced User
Is this undefined wall-port configured to allow one computer only, or is a modem only' Each would allow one computer only, with just one IP address.
