DM56's avatar
DM56
Follower
Sep 05, 2021
GS308-3 adding a second ethernet switch FS105 with jumper
Can you use a jumper to stack two switches? Netgear 8 port with 5 port added with jumper cable. Home application, ran out of ports on the GS308. want to add FS105 switch for the additional ports.
  • plemans's avatar
    not sure what you mean by jumper.
    You can connect 2 switches together with an ethernet cable. I've got multiple switches
  • schumaku's avatar
    schumaku
    If "jumper" means a straight instead of a standard crossed (X) cable the answer is no. Modern switches have a feature called Auto-X.
ProSupport for Business
