Mikeyb0715
Jun 22, 2020Initiate
GS308v3 to Modem connection problem
Hey everyone and anyone, Just recently bought a Gs308v3 switch to help with extending port availability during these crazy times. I connected into port 1 the cable from my router and in port 2 conn...
- Jun 22, 2020
Just wanted to check if it was the modem (where ISP assign only one IP typically - so other devices can't access the Internet). Easy to make a mistake wit that many devices and cables. Happy you figured out the connection mishap!
schumaku
Jun 22, 2020Guru - Experienced User
What now - is that device before ... a modem or a router?
What IP address does that MacBook receive? An RFC1918 private address like 192.168.x.y, 172.2x.y.z, 10.a.b.c - or a public IP address (or again a CGN IP address 100.64.c.d)?
Mikeyb0715
Thanks for the reply, I was a dummy and connected it to a modem first when i should've been connecting to the router.
- schumakuJun 22, 2020Guru - Experienced User
