myststars
Nov 04, 2021Tutor
GS316 -- Very slow download speeds
Hi All I bought the Netgear Gs316 to replace a 10+ years old 16ports switch.Before the switch was 100mbps and download was around 90mbps.After i inserted the netgear gs316 the download is capped a...
Nov 04, 2021Guru - Experienced User
it usually doesn't limit to 20/50mbps. If there's an issues, its usually when a cable is sketchy and dropping speeds from gigabit to 10/100mbps connections.
I'd start at the basics and disconnect everything from the router and then add pieces in 1 at a time. Test the speeds each time you add something. Then, when you do find what device is causing issues, try swapping ethernet cords around since I've seen ethernet cords be sketchy.
The GS316 is an unmanaged switch so they usually either work or don't work. there isn't anything inspecting traffic. They only time I see a switch like this causing slow downs is again the dropping from gigabit to 10/100mbps.
myststars
Nov 05, 2021Tutor
I plugged the ISP router directly to a laptop and made speedtest and all servers i tried are capped at 21 mbps.I called the ISP and they will send a team on monday to check.
- plemansNov 06, 2021Guru - Experienced User
Good luck! Let us know how it goes
- myststarsNov 08, 2021Tutor
The funny aspect was that the contract that they made was 10mbps.Somehow the ISP have not received correct file and worked .... differently.The ISP believes when i changed the switches triggered also the routers to ask for the configuration.Is still above the contract with 25 mbps as an irony.Even does not explain how.My signal goes to my current company hq in the capital city and is filtered there.
So the switch is not the fault.
