bvz's avatar
bvz
gs316 seems to kill network traffic
I just purchased a new GS316 for my home.  Unfortunately, anything running through that switch seems to run extremely slowly.  To the point that my web pages that I am trying to access actually timeo...
  • ElaineP's avatar
    Dec 27, 2016
    Hi bvz,
    Welcome to NETGEAR community!
    At first, please reduce your temperature, the switch can bear the range:
    Operating temperature 0°–40°C (32°–104°F).
    If your closet is 58 degrees, maybe the switch chipset will have higher degrees.
    The second point, if your switch can support power saving function, please try to disable it. Due to it can control your traffic for power saving.
    Look forward you reply, thanks.
    NETGEAR Employee
ProSupport for Business
