growly
Feb 13, 2021Tutor
GS316 switch dropping link with some NICs
This is very weird. I have two examples of this switch misbehaving when establishing a link:
1) Currently, when I connect my PC to any port (using multiple different cables), the connection drops randomly every 1-2 hours and immediately re-establishes. If I turn off autonegotiation and force 1000 full duplex, it happens less often. I've seen the problem in Windows and Linux on the same machine. When I plug the machine into a different switch, there aren no problems. (The PC has an Asus Prime X570-Pro motherboard with an Intel I211 NIC onboard, using igb module under Debian testing with Linux 5.10/Windows 10 Microsoft drivers).
2) Previously, when plugging the Aquantia 5 gbps chipset of an Asus Prime X299-Deluxe II, no link could ever be established. The port would work when plugged into a different switch though.
In each case I have tried multiple different cables so they are likely not the problem.
It looks like this switch can't auto-negotiate with all chipsets, which is weird, and which leads me to think there's some problem with its implementation.
Has anyone else run into this? Is there anyway to diagnose?
Also, the product brochure says "lifetime warrant", but I can no longer get support for it. Can it be RMA'd?
- DaneANETGEAR Employee Retired
Are the software drivers of the LAN adapter of PCs you are on the latest version? If not yet, kindly update it then check if the same problem will occur.
As per page 4 the GS316 data sheet here, the switch has a 3-year Hardware warranty and 90-day free Technical Support warranty upon date of purchase.
DaneA
NETGEAR Community Team
- growlyTutor
The drivers are the latest versions I can get.
I replaced the switch with a non-Netgear switch and the problem has gone away.
Thanks for the feedback. Now that the problem is isolated, I suggest you to open a chat/online support ticket with NETGEAR Support here at anytime to let them know the status of your switch and get a replacement (as long as its still within hardware warranty).
DaneA
