Chris_Chelt
Aug 17, 2024Follower
Gs324v2 Port
Hello everyone,
I have just purchased a Netgear GS324v2 switch for my home network and I have set it up as I normally would by attaching the ethernet cable from my router to port 1 and then everything else to the other ports but upon looking at the manual that came with it they show the router connected to port 24 which seems odd. I just wanted to check if there was any need for this or is the manual wrong or am I wrong or does it not matter? I am confused because every other switch I have ever owned says use port 1 for input and the rest are outputs....
I use port 24 on mine, that way for connection and wall ID or device ID, one can use port 1 for a ID of 1. For sequencial ID naming.
If you don't use this then you can use port 1 for the connection to the host router. I don't think it matters when it comes to non managed switches. User preference. - RennaDNETGEAR Moderator
Hello Chris_Chelt,
Welcome to the NETGEAR Community! 🙂
You can use any port as input/uplink port to the router. There is no specific port assigned for this.
If ever your concern has been resolved or answered, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Have a lovely day,
RennaD
Netgear Team
