jfadams
Mar 16, 2026Tutor
GS605AV replacement
My old GS605AV switch worked great as a simple Home Theater and network switch until yesterday. Now it will not power up. According to the GA605AV installation guide the GS605AV would “optimize audio...
- Mar 16, 2026
A GS105 or GS305 should be given a try. There just non mangaged switches and would work well in general Home Theater system. I use a GS316 and GS308s in my HT system.
jfadams
Mar 16, 2026Tutor
Typo: “GA605AV installation guide” should be “GS605AV installation guide”…
