jfadams
Mar 16, 2026Aspirant
GS605AV replacement
My old GS605AV switch worked great as a simple Home Theater and network switch until yesterday. Now it will not power up. According to the GA605AV installation guide the GS605AV would “optimize audio...
Mar 16, 2026Guru - Experienced User
A GS105 or GS305 should be given a try. There just non mangaged switches and would work well in general Home Theater system. I use a GS316 and GS308s in my HT system.
