Confused_in_ID
Oct 09, 2017Aspirant
GS608v4 - Firmware Update?
Is there or is there not a firmware update to the NetGear GS608v4? I have an email message from NetGear urging me to updat the firmware; the website seems to say there isn't one for that model. T...
- Oct 10, 2017
You're welcome! I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Oct 10, 2017NETGEAR Employee Retired
Hi Confused_in_ID,
Welcome to our community!
GS608v4 is an unmanaged switch. It is just a plug and play device and it doesn't have any GUI.
You may check the reference here.
Confused_in_ID
Oct 10, 2017Aspirant
Thanks, JohnCarloV. Thought so but confused by the email.
- JohnC_VOct 10, 2017NETGEAR Employee Retired
