Rjam809203
Jul 24, 2016Follower
How can i make an gs108tv2 manned to unmanned?
Want to make my gs108tv2. Unmanned is it possible.
Hi Rjam809203,
Welcome to the community!
By default, the GS108tv2 runs like a passthrough switch. As long as you do not configure VLANs, QoS , etc,. ot should run like a basic dumb switch.
Thanks,
- omicron_persei8LuminaryWhat do you mean by unmanned?? What are you trying to achieve?
- JohnRoNETGEAR Employee Retired
Hi Rjam809203,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future! Jeremiah ReyesThanks,
Hi Rjam809203,
Thanks,
