Aladine
Feb 21, 2017Aspirant
How to find the CPU in a network device ?
Hi, As you know probably there is an open issue with "some" CPU, and as you also know a program is started by a competitor for the replacement of "some" devices. And I know, I know, I'm apologize...
- Feb 24, 2017
Hi Aladine,
I have seen the posts online regarding the issue with Aton C2000 processors. I have inquired this to our engineering team but it appears that this information cannot be disclosed to avoid misinformation. For these models switches CPU chips may be different across batches. I have searched most of our products, but only some of our ReadyNAS units maybe using the said CPU family chip.
Thanks,
JohnRo
Feb 22, 2017NETGEAR Employee Retired
Hello Aladine,
Welcome to the community!
Can you post a link regarding the CPU issue? I'd like to know as well what is the model number of the swicth you are referring to.
Thanks,
- AladineFeb 22, 2017Aspirant
Hi JonRo,
My model is the GS116v2, an "in between" manageable switch.
The issue what I spoke over is, of course, the Atom C2000.
But as I wrote, I juste want to find the kind of the processor installed in the GS116v2 switch.
The only Aladine with a white beard.
- JohnRoFeb 24, 2017NETGEAR Employee Retired
Hi Aladine,
Thanks,
- AladineFeb 24, 2017Aspirant
Hi JohnRo
Thanks for the information.
I consider this topic as close.
Kind Regards,
Aladine
- JohnRoFeb 27, 2017NETGEAR Employee Retired
Hi Aladine,
You are welcome, I apologize if the information you are looking for cannot be disclosed. If this answers your question at least we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
