Porknz
Jun 03, 2024Aspirant
How to test if my switch is bad
We had a storm last night. Now all of my electronics are down. Items connected to the router work. The router connects to the Netgear switch. Items connected to the switch do not work. Before I try to...
Salpha
Jun 04, 2024Aspirant
Try this
Reboot the switch turn it off and wait 30 seconds then on.
Test each port with a known good cable and device.
Reset the switch check manual for instructions
Porknz
Reset as in find some place to push a button with a paperclip?
- schumakuJun 04, 2024Guru - Experienced User
Porknz wrote:
Reset as in find some place to push a button with a paperclip?Unlikely there is one, as you talk of an unmanaged switch here.
Power LED .... you already mentioned power looks ok.
Port LED ... links and activity, as power the fine user manual or basic installation guide?
