Gartmand's avatar
Gartmand
I am in need of a letter of volatility for a JGS516
I need a letter of volalitility for a prosafe 16 port unmanaged switch model JGS516.
Thank You,
Debbie
  • Hi Gartmand,
    Welcome to our community! :)
    Here is the latest letter of volatility for JGS516. No password needed and the link will expire after 48 hour period.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi Gartmand,
    • Gartmand's avatar
      Gartmand
      Is there a letter of volatility for the jgs516 model and not the jgs526v2?
    • Gartmand's avatar
      Gartmand
      I'm so sorry. I was informed a letter of volatility is needed for model JGS516NA specifically. Do you have this available?
      Thank You,
      Debbie
      • JohnC_V's avatar
        JohnC_V
        Gartmand,
        Here is the letter of volatility for the JGS516NA. Let me know if this would suffice :)
  • Is the a letter of volatility for the jgs516 model and not the jgs526v2?
ProSupport for Business
