aurosharman
Mar 10, 2018Aspirant
Is the EN104 a hub in the sense of repeating incoming packets to all other ports?
I'm looking to pick up a few ethernet hubs, for network troubleshooting use -- stick a hub between two devices, tap in a computer running WireShark, and analyze the traffic. It's starting to become ...
- Mar 11, 2018
Don't know about the EM104 effective implementation. Not sure you will be happy with just 10 Mb ports for the purpose intended.
Nowadays one does make use of a (light) managed switch supporting port mirroring like all Netgear Smart Managed Plus or Smart Managed Pro devices for example. Classic hubs are history. For specific usage, more challenging, and expensive are dedicated Network TAPs.
schumaku
Mar 11, 2018Guru - Experienced User
- aurosharmanMar 12, 2018Aspirant
For my use case, slow is fine, I'm looking at devices that are supposed to upload a range of 40-200 MB of data per day. In some cases they have trouble getting a link through to our cloud services, and a pcap can help figure out what's going wrong... I guess converting a managed switch for mirroring works. It's just easier to have something that by default does what I want it to do, with no config.
- SamirDSep 25, 2026Prodigy
Nearly a decade late on the reply, but I bought several of these when they were new and yes, they are a straight hub and the packet is broadcast to all the ports just like a classic hub should do. If you have the regular version, it even has a BNC port on the back that can tap BNC traffic (if you have anything using this these days). I think the biggest problem with these which I didn't realize with my units until I had already started using them as book ends is that the power supply will go bad and make the units seem like they are bad. I haven't confirmed my theory yet, but I suspect it strongly as the units themselves were really well made by Bay Networks back in the day.
