Mstats
Apr 02, 2019Aspirant
Is the GS305 Switch compliant for Thailand?
I have a customer asking if the GS305 Ethernet Switch is compliant for Thailand. I believe Thailand has thier own Safety/EMC Mark, but curious if Thailand accepts the CE mark.
Mstats
- Apr 04, 2019
Hi Mstats,
I believe that would be the right course of action since the GS305 switch model as well as the specification of the power adapter for the GS305 varies by region (in this case it should be Asian region) as per the GS305 Installation Guide here.
DaneANETGEAR Community Team
Mstats
Thank you DaneA, the Netgear Compliance document was more than I have seen so far, but the information was sparse under the Thailand section, "The information in this section applies to products approved by the Thailand National Communications Commission"
The "section" doesn't provide any information about Netgear products, so I have to believe Netgear doesn't have any products that comply to Thailand's standards.
Is that what you interpret?
Thanks again,
Mstats
DaneA
Apr 04, 2019NETGEAR Employee Retired
Hi Mstats,
I apologize for the late response. I already sent an inquiry to the higher tier of NETGEAR Support about your concern. I will post here once I got a feedback.
DaneA
- MstatsApr 04, 2019Aspirant
Hi DaneA,
No problem, I'm hearing through other sources that the Netgear Switch will have to be purchased from a Thailand distributor.
Thanks,
Mstats
