aacnet76's avatar
aacnet76
JGS516PE led lights no working
hi i got the JGS516PE switch, it is working, internet and POE cameras, but none of the lights are ON   there are no buttons on anywhere of the switch to turn them on, neither the utility, it has ...
  • schumaku's avatar
    schumaku
    Jul 24, 2018
    Must be a well-kept secret ....:
    myNetgear -> My Support -> [Contact Support] -> Replace my defective product -> select the switch from the product list -> you will get a contact information -> provide some descriptive text ...
ProSupport for Business
