Tim-in-oz's avatar
Tim-in-oz
Follower
May 19, 2016
JGS524 v2 - fanless or not?
Hope someone here can help - simple question 1) Is the JGS524 v2 fanless or does it have a fan? (not specified on its spec sheet) 2) If it has a fan - how loud - thinking of using in the domestic ...
  • JohnRo's avatar
    May 20, 2016
    Hello Tim-in-oz,
    Welcome to the community!
    Yes, it (JGS524v2) does have a fan. Though some of our 24-port models may be fanless for a more quiet operation. I can't provide numbers for the loudness, but it is not really loud since the fans are small. I can probably compare it to the noise a regular 24-port non PoE switch model.
    I hope my answer helps.
    Thanks,
ProSupport for Business
