daro346
Nov 21, 2015Follower
Netgear FS205 drops offline
I am using a netgear fs205 as a switch. I am connecting a few devices to my network. The network keeps dropping offline. when I connect to a different switch or directly to the router, the problem doesn't happen. It's a new switch. Is it defective?
Welcome to the community, daro346 Just to be sure, did you try using a different ethernet cable?
If it's the same, I suggest that you get a replacement.
1 Reply
