MunichDSLer
Mar 10, 2022Aspirant
NETGEAR GS108LP Loss of power triggers restart
I am running a unifi wifi system over my GS108LP and noticed since I got it that whenever we have a short powercut, this usually happens when the washing machine starts pumping out water, I loose pow...
MunichDSLer
I am using 4x Access Point WIFI 6 Lite, the UPS I added due to the fact that we had these restarts, this isn't the cause unfortunately
schumaku
Mar 10, 2022Guru - Experienced User
Ok, not near to the power limit.
Well possible a simple VFD (Voltage Frequency Dependent from Mains Supply) aka. standby- or offline-UPS will not become active until the AC power does completely fail, and won't make any difference if the voltage is dropping due to certain higher load on your installation. A VI (Voltage Independent from Mains Supply) aka. "line interactive UPS" and of course VFI (Voltage and Frequency Independent from Mains Supply) aka. "online UPS" would help keeping the power supply up.
