Teenet
Jan 04, 2017Guide
Netgear GS116 v2 16 port switch Power led blinks
Hi, I just received a new Netgear GS116 v2 16 port switch, unpacked it and connected it to the power supply and to a network cable. Immediately I found out that the power led on the switch is blin...
- Jan 06, 2017
Hi Teenet,
There must be something wrong with the power supply, it could be grounded or damaged. You can also contact our support team to get a free power supply replacement.
Thanks,
JohnRo
Jan 04, 2017NETGEAR Employee Retired
Hello Teenet,
Welcome to the community!
The GS116v2 is only a plug and play switch. It does not require any software for it to work. When you said reset, are you pertaining to just rebooting the device? What is the color of the power LED when it blinks?
Looking forward to your response.
Thanks,
