Teenet
Jan 04, 2017Guide
Netgear GS116 v2 16 port switch Power led blinks
Hi, I just received a new Netgear GS116 v2 16 port switch, unpacked it and connected it to the power supply and to a network cable. Immediately I found out that the power led on the switch is blin...
- Jan 06, 2017
Hi Teenet,
There must be something wrong with the power supply, it could be grounded or damaged. You can also contact our support team to get a free power supply replacement.
Thanks,
JohnRo
Jan 05, 2017NETGEAR Employee Retired
Hi Teenet,
There might be a little mistake with the model number you have posted since the GS116v2 is NOT a smart switch. Can you please PM me the serial number of your device so that we can identify the correct model number? I cannot give recommendations for now since I am unsure on what model you are working on.
Thanks,
Teenet
Jan 05, 2017Guide
Oops, my bad... It's the Netgear Prosafe GS116Ev2...
Do you still need me to PM you the s/n ?
Thanks again! :smileyhappy:
- JohnRoJan 05, 2017NETGEAR Employee Retired
Hi Teenet,
That's okay. :) I know some of these models are a bit confusing, no need to PM the serial number. I suggest installing the ProSAFE Configuration Utility and see if the switch will be detected. The power LED should be solid and the Ethernet lights should blink if there's an activity.
Thanks,
