Teenet
Jan 04, 2017Guide
Netgear GS116 v2 16 port switch Power led blinks
Hi, I just received a new Netgear GS116 v2 16 port switch, unpacked it and connected it to the power supply and to a network cable. Immediately I found out that the power led on the switch is blin...
- Jan 06, 2017
Hi Teenet,
There must be something wrong with the power supply, it could be grounded or damaged. You can also contact our support team to get a free power supply replacement.
Thanks,
Teenet
Jan 05, 2017Guide
And if it's not solid again? Could it be a defective power supply? Could it be something else?
Thanks JohnRo.
Thanks JohnRo.
JohnRo
Jan 05, 2017NETGEAR Employee Retired
Hi Teenet,
There is a chance that it could be a bad power supply, the power LED is not supposed to blink. Did you try if the switch is detected by the utility or if it even passes the IP from your DHCP server?
Thanks,
