Teenet
Jan 04, 2017Guide
Netgear GS116 v2 16 port switch Power led blinks
Hi, I just received a new Netgear GS116 v2 16 port switch, unpacked it and connected it to the power supply and to a network cable. Immediately I found out that the power led on the switch is blin...
- Jan 06, 2017
Hi Teenet,
There must be something wrong with the power supply, it could be grounded or damaged. You can also contact our support team to get a free power supply replacement.
Thanks,
Teenet
Jan 05, 2017Guide
Hi again,
Yes, I'm able to login to the utility and config all the settings. It also passes the ip from the dhcp server without any problems. The only issue is with the blinking power LED. What kind of power supply should I buy? 12v 1A is a must or can I use a 12v 2A 24w max which I have at home?
Thanks again..
Thanks again..
- JohnRoJan 06, 2017NETGEAR Employee Retired
Hi Teenet,
It would be best if you use the same Voltage and Amp like the one supplied. I have not seen such LED behavior for this model. If the power LED blinks do you lose connectivity to the switch?
Thanks,
