Teenet
Jan 04, 2017Guide
Netgear GS116 v2 16 port switch Power led blinks
Hi, I just received a new Netgear GS116 v2 16 port switch, unpacked it and connected it to the power supply and to a network cable. Immediately I found out that the power led on the switch is blin...
- Jan 06, 2017
Hi Teenet,
There must be something wrong with the power supply, it could be grounded or damaged. You can also contact our support team to get a free power supply replacement.
Thanks,
Teenet
Jan 06, 2017Guide
Yep. When it blinks I can't connect to it. The only way to reconnect is to unplug it, wait a few minutes and then plug it in again.
- JohnRoJan 06, 2017NETGEAR Employee Retired
Hi Teenet,
Thanks,
