Teenet
Jan 04, 2017Guide
Netgear GS116 v2 16 port switch Power led blinks
Hi, I just received a new Netgear GS116 v2 16 port switch, unpacked it and connected it to the power supply and to a network cable. Immediately I found out that the power led on the switch is blin...
- Jan 06, 2017
Hi Teenet,
There must be something wrong with the power supply, it could be grounded or damaged. You can also contact our support team to get a free power supply replacement.
Thanks,
Teenet
Jan 06, 2017Guide
OK. I will do that!
Thanks! I appreciate your assistance! đ
- JohnRoJan 06, 2017NETGEAR Employee Retired
Hi Teenet,
You are most welcome! Please update this thread once you were able to get it replaced and tested. :)
Have a great day!
Thanks,
- JohnRoJan 16, 2017NETGEAR Employee Retired
Hi Teenet,
Weâd greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the âAccepted Solutionâ so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
